EVC860 Bogging down
BrentW
My scag TCII with he EVC860 is bogging down under a load and flashing a 0174 lean fuel at high throttle code, Anybody have a quick fix to try before loading up to take a long ride to the dealership?
Most of the hints point to O2 sensor issues or wiring, an exhaust leak. Bad fuel pump or plugged fuel filters. Or possibly engine ground wire issues.
BrentW
Any idea where the motor ground is located?
hlw49
Had a ECV680 doing the same thing and it turned out to be the O2 sensor. Unplug the O2 sensor and see how it runs.
