I have a Briggs 190412-3098-01 880122110. The engine was running but not good. The carburetor needs some work on it. I pushed the metal tab onto the spark plug to shut it down and the engine kept running. I pulled the spark plug wire off and it kept running. I had the plug wire about 3 inches from the plug and could not see a spark jumping the gap. I finaly choked the engine off. Why is the engine running with the plug wire off? Thanks for any help.
