When you say reassembled what all do you put back on? Just the cover?
OK while looking for the solenoid ( which I still have no idea) I wiggled connections , moved the starter. Worked twice. Now not sure what to think. I know the second I put all back together it will stop. Any thoughts ?
Which tells me loose/poor/mice chewed wiring and or connectors/connections. Or when you jiggled the starter, the starter gear went up and contacted the flywheel momentarily.OK while looking for the solenoid ( which I still have no idea) I wiggled connections , moved the starter. Worked twice. Now not sure what to think. I know the second I put all back together it will stop. Any thoughts ?
