I searched for my problem before posting a new thread but did not find anything.
It's probably out there but may be buried on page 101 or something.
Ok I have a Scotts S2048 mower with a Kohler Command CV730S engine. So I go to cut my grass yesterday and the mower starts with no problem. After a very brief warm up I engage the PTO and she dies. So I am thinking no big deal, it has happened a few times when I do not let the engine warm up long enough.
Try it again, starts right up and dies when I engage the PTO switch only this time it will not restart. Just a click and the engine does not turn over. I slap a charger on the battery overnight and come back this morning and still the engine will not turn over. I remove the plastic bug cover from the top of the engine and try to turn it by hand but she is locked up. Even used a pry bar in the cooling fins with no luck.
Pulled the starter to see if it was somehow jamming the engine but it was fine. The starter spun by hand easily so I am wondering if it might be the PTO clutch or if there is some internal engine damage. I am going to pull the plugs and see if it will turn over then but is it possible the PTO clutch could be the culprit? Would it lock up an engine? Thought I'd ask before pulling it off to check it out.
Oh yeah I also tried bypassing the solenoid and jumping it off that way. Checked the fuse as well and it was good.
