have a briggs model 286H77-0121-E1 serial number 020624ZA. engine will not stay running. first solenoid was bad, replaced carb with aftermarket carb. mower will for few seconds. did compression check only 45 psi, getting spark. replaced spark plug. so not sure if due to low compression this is causing mower not to stay running. any advice would be helpful
thanks
AC
thanks
AC
