Before the pros arrive to give their advice I would remove the air filter and squirt some carb cleaner into the carb to see if you get a sputter. You could also give a little shot into the spark plug hole, bypassing the carb. If you get a sputter Its most likely a fuel issue. If you get noting, I would check for spark next.
