RobertMo65
- Mar 28, 2017
- 2
- 4
Here is the background information:
John Deere Z425 (2011) with Briggs and Stratton 23 hp (model 44L7770144G1)
When I went to start the engine, no problem. When placing choke lever to run it shuts off and will not crank again. The engine turns over but that is it. I cut grass last week without any problems. Things that have been checked this time or replaced last time: Spark plugs are clean, replaced last year, tested with a plug tester. Fuel pump replaced last year and tested this time for fuel discharge. Replaced fuel filter last year, verified it is clean. I don't suspect any of the safety interlocks because the ones I have tested won't allow the engine to even turn over. Checked the oil in the operating band. I took it to a shade tree mechanic last year and of course it started right up when I got there. Any ideas or suggestions are greatly appreciated.
Thanks
Robert
Thanks
Robert
