Engine transplant
thinkglad
I have a JA65 with a Briggs 12J802-1753-E1 motor that has a bad camshaft. I found a running 126T02-0675-B2 for $25.00
Not sure if it would be a direct "plug and play" replacement or not.
Anybody out there know?
Thanks
It will work depend on when the engine was built. Please post the code numbers for both engines.
If everything I find is correct and I believe it is, yes you can make the swap. Good Luck.
