I have a Troy Bilt Bronco with a Kohler SV 590 19 hp. engine that I have been working on. Last week a friend gave me his Cub Cadet RTZ 42 with a Kohler SV530S 17 hp. engine that blew up on him. I am thinking about swapping the engine from the Troy Bilt to the Cub Cadet and then I will have a zero turn with a newer engine. From what I have found out the only difference I see is that the shafts are a different length. The 19 hp. shaft is 3/32" shorter than the 17 hp.
Does anybody have any experience with this type of swap, any suggestions, or what to look out for.
The only real doubts I have is fitting the pulleys and the PTO to the shaft.
