Engine suddenly will not start
Compression, was online to see how to test it... one site suggestion was to spin it backwards by hand It should bounce back again at the point of compression. If it does, compression is not the starting problem. With larger engines which are difficult to spin, try to turn it as fast as possible and feel for a definite springy compressed air resistance. I tried that and it turns fairly freely by hand in either direction, it that a bad sign for this engine? I can hear a sound of air exiting in both directions
thanks for everyone help.
Briggs and Stratton
Model and type
31C707 015E1
Sounds fuel related. Can you make it run for several seconds by spraying the starting fluid in spurts, directly into the carb, and then it dies when you stop spraying?
Hey, this is my issue exactly on my pressure washer! I have already completely removed the carb and cleaned it, made sure all holes were open by poking wires through.
When I re-attach everything, I can get it to fire up after spraying starter fluid in, but after a second or two, it dies.
Lets see - what else have I done...
- I also have fresh fuel in the tank
- cleaned the air filter
- inspected the fuel line - needs to be replaced, but is serviceable for the moment
The engine is a B&S Quantum 6.0 hp
Any suggestions would be welcomed!
got a tester and no compression.. looks like bad news... the flywheel moves fairly freely in both directions by hand. just strange that it would fail so bad by just turning off the mower with a small backfire.. it was working fine until then...
any other ideas other than a toasted engine...
I was mowing my lawn and stopped the engine to answer my sons question. when it stop it backfired, which happens on occasion 5 or 6 time a year. when I went to start it, it would turn over and not start...
It has started fine every since I had it (9 years) and had started fine the 3 times I have use it this year...
tried to some fuel in the carb, changed the spark plug, and oil is fine .. nothing has helped... it does seem to do a small backfire every once in a while when I try to start it..
any thoughts on next steps..
maybe flywheel key
Got mine figured out!
I replaced the rubber gasket that the needle fits into
I replaced the fuel line
Then when these did not resolve the issue, I kept poking and prodding and ended up going back to the screw in the reservoir... I found a slender needle and poked it through the hole in the top of the screw and finally(!) My engine roars to life and stays alive!
With the valve cover off, turn the flywheel by hand and watch the valves, tell us what you see.
then take out the plug and put a pencil in the plug hole
and rotate easy and see if the piston goes up and down.
