Timothy White
- Apr 1, 2019
- 1
- 4
I have a Craftsman lawnmower with a Briggs & Stratton 6.75 engine (model #126T02) with automatic choke, which was given to me used and broken. After cleaning the varnish and trash out of the carburetor, I got it to run, but then it ran intermittently. It ran strong for a few hours, once, but since then it runs for 10 seconds, 10 minutes, until you put the engine under load by cutting grass, and then it dies. I can't get any clear understanding of what causes it to die, or why it was able to run for hours just a couple days ago.
I've watched a youtube video about the automatic choke, and I understand how that and the "governor" work. I've adjusted the metal plate to cause the engine to run quite fast and it still dies. I've disassembled and cleaned the carburetor at least 3 times, and each time I do this I find specks of crud in it. The bowl gasket is in terrible shape. The bottom is "fringy" and deteriorated and the gasket has expanded so that it's actually larger in diameter than the bowl. I have to use a small screwdriver to push the gasket into place all around the circumference of the carburetor bowl, to prevent it from getting pinched when the bowl is tightened.
So I know the carburetor bowl gasket is bad, and I've ordered one and it will arrive in a few days. I'm posting this thread in case there's another problem that causing this. I don't want to replace the bowl gasket and find out something else is the cause of the problem. So I have several questions.
1) The Youtube video I watched show a professional mechanic and he showed something he called the "float alignment" which was that when you turned the carburetor upside down the bowl was supposed to be level with the carburetor, more or less. He said if it's not level, it's bad. My carburetor is not level. When I turn it upside down, the float is pushed upwards, as if the needle is too long, and not by just a little bit either. It sits at least 1/8", maybe 3/16" inch higher than what I would call "level". The mechanic on Youtube talked about how the needle wouldn't "properly seat", which I assumed meant the gas would never shut-off to the bowl. In my situation it seems to me that the float would never stay open long enough to completely fill the bowl, since it would close the valve off too early. Half-filled bowl.
I just want to know if this could actually happen (is my analysis correct), and could this explain my situation. Has anyone ever seen this before? The engine had been worked on, and I wonder if the wrong bowl, needle valve, or even the whole carburetor is the wrong part.
2) Is there some kind of temperature protection system that is either working, and my engine is overheating, or it's not working, and killing the engine when it shouldn't.
3) Could there be a problem with the kill switch? There's a handle that kills the engine (somehow). It starts REAL EASY, as long as I give it a couple squirts of gas with a spray bottle. Which makes me ask:
4) I have the whole air filter assembly removed, since this engine does not have a primer on it. Does the engine need the restriction of the air filter in order to run properly?
Thanks in advance.
Thanks in advance.
