Give us the model and spec numbers for the engine. Also, did you purchase an OEM carb or just one off the Internet which they say will work for your engine? What was the part number for the new carb?]
Thanks, Rivets. The model number for the mower is 917.383280. Here are some of the specs:
HP: 3.5
Spark plug: .030 inch gap; Champion RJ19LM/Sears 33312/STD 361458 or 360950
Valve clearance: Intake .008 inch; Exhaust .008 inch
Solid state ignition air gap: .0125 inch
Engine: Craftsman model 143.424012
20" rear discharge
As I told CPurvis, I obtained the replacement carb from Sears. The part number for the carb is 632795A, which they said replaces the original carb (part number 632046A). I believe the replacement carb is OEM, but I have no way of knowing. I'm only taking Sears' word for it, but I can tell you that 632795A definitely wasn't designed specifically for that mower; only 1 of the 3 seals for the new carb they sent even aligned properly, though they appeared to create a solid seal...
All that being said, I don't necessarily believe that the new carb is not functioning properly, as the mower is still doing exactly what it did (start, then die) before I replaced the carburetor...
