Hi Walt
I have Toro riding mower and I was curious if you would know why they would make it so it slows to a crawl when you turn the steering wheel. It only goes 3 or 4 MPH when going straight and when turning the sharper you turn the slower it goes. It only goes about 1/2 MPH in a sharp turn. 3 or 4 MPH isn't fast enough to upset even in a sharp turn. When mowing I turn a lot and it was so annoying I got rid of that feature too.
Dana
Easy one to answer.
When used in a dangerious mannar contry to the instructions in the operators manuals some mowers can tip over when turning too sharply at too high a speed.
Mr Idiot Moron gets new mower charges strait into the yard, tips the mower over and severs his spinal column so he can no longer work, pay the mortage feed the family.
Mr Smarty Pants lawer mounts a case against Toro and bumps it around court rooms till he gets a creationist judge who awards a massive damages claim against Toro who are then forced to modify their mowers so no brain dead idiot moron can possibily hurt himself.
We got thousands of Rider Pro's down here after the courts banned them in the USA because if you turn too tight on a slope larger than he maximim allowable mowing slope the mower flips over.
A little latter Husqvarna modified the design and you got the USA only Pro Riders.
Blade cut offs became manditory because of all the idiot morons who shove their hands in the discharge chute to clear a blockage but if you go to your local casulty you will find they still get loads of hand injuries due to operators clearing out the discharge chute with their hand. Then ask them how many brain dead come in missing a finger because they tried to "flip" a belt back onto a moving pulley. All of these clots dissabled the seat switch following the instructions of all the You Tube experts then found out why it is there.
Mowers are very price sensitive so no mower makers goes around looking for expensive safety features to fit to their products.
As for me I would be happy for all safety features to be removed from all mowers then hopefully a lot more idiots would kill themselves hopefully before they had time to breed more idiot morons.
Down here when you take delivery of a new mower, the delivery man takes the key with him.
Your keys are inside a sealed envelope with the message "Read Operators Manual before using mower- serious injuries can result from improper use "
The envelope is stapled inside the instruction book with all of the other paper work inside a sealed plastic bag with a similar warning printed on it.
