I have a Kawasaki FD590V that puffs smoke on start up. It burns clean in a few seconds and runs good at all engine speeds. Are these engines prone to valve seal failure or is it something else causing the smoke? Thanks in advance.
How many hours do you have on the engine ?
It has 1365 hours. The smke is just at startup. Thanks
