After about 10 minutes of good mowing my Deere Lt 180 engine starts shutting down as if running out of gas. If I pull out on the choke it will recover and will run for a little while and starts all over. Replaced fuel filter, fuel pump, plugs, ignition coils, pulled gas tank and drained, blew thru gas lines, cleaned air filter and nothing helped. Thanks in advance for help. Bill. Engine: Kawasaki V-Twin,17 HP, FH500V, 4 cycle
