Kohler 22 Command
I was cutting grass when suddenly the mower shut off for no apparent reason, not a stumble just quickly shut off.
1. Attempted to restart and would not crank. None of the dash lights were lighted either.
2. Battery has been fully charged and no improvement
3. Battery terminals are corrosion free and cables are secured on both ends.
As a side note when normally starting I have to at times cycle the key a few times before it will begin to crank. Typically always lighting the dash lights but not always cranking.
Does this sound like an obvious problem or can anyone tell me what to check?
Check all safety switches. Sounds like one of them is being triggered.
