It sounds to me like you may be running your engine a bit too lean. You can richen up the mixture with the two screws on the side of the saw, L for low and idle H for high speed. Probably wouldn't hurt to turn both out at least 1//4 turn counterclockwise, maybe more if the saw still runs all right.
Thanks, will try it.
