engine seized - freed up but now won't start - Toro
jays
  • / engine seized - freed up but now won't start - Toro
The exact same scenario played out today with my 22" Toro. I am now able to turn the blades by hand and pull the start cord. However engine will not start. There seems to be some very good recommendations resulting from your thread. Were you ever able to get your Toro running again?
twinfords
Rivets is dead on, check the flywheel key, get a friend to help you check for spark, go from there. you can see once the cup is removed if the key has moved,
