Trying to figure out what the output RPM is on my BS 126312-0580-B8 engine. Can't find any specs.. It's a horizontal shaft engine off a tiller.
Reason being.. I'm trying to find a grease to put in the gear case of the tiller. JD corn head grease is for 1000 rpm or less near as I can tell. The recommended stuff is like $25 for 8oz and I need 22oz.. Not sure the thing is even going to work, so don't want to spend $75 on grease... I found a pulley calculator, but not sure of the output shaft speed. Thanks!
