unioncreek
- Sep 5, 2016
- 70
I'm in the final stages of rebuilding the engine in my MTD model # 13AN682G129. I need to replace the double pulley due to the drive pulley being so worn out that the belt would slip most of the time on it last year unless I put it in high gear and got it moving first. They want ~$65 dollars for the pulley, but I see other pulley that are very close in size that are less than half that price. Onthat I found the deck pulley was the exact same size but the drive pulley is 3/8" bigger. Would this be too big to be able to work?
Bob
Bob
