Dennis1971
- May 10, 2019
- 1
- 1
I have a Ferris zero turn with a Briggs 30hp Model 49M977-0114-G5 motor on it. Its about 5 years old and has less than 200 hours on it. At 100 the oil sump pan gasket blew out and I changed it and it was fine for over a year. Then today I had been mowing for about 10 minutes and it messed up on me. So I drove it in the garage and there was oil coming out from somewhere maybe the oil sump pan again or above it, couldn't really tell where it was coming from. The motor had no power and would make a noise once in awhile like something pinging inside. So I did a compression test and had 150 psi on the first cylinder and then 0 on the second. Put a screwdriver in the spark plug hole and turned the motor over by hand and can tell the connecting rod is broken or something, piston does not move. So should I order a new motor or have this one repaired? Have no idea what it would cost for repairs. I have the Briggs 49M977-0114G5 and looked online and chatted with a place that came up and they said this motor is no longer available and I need to go to the Briggs 49T877-0004-G1 instead. Anyone know anything about this or if Briggs has made any improvements with this newer model? The original one was a 30hp and this one is advertised as 27hp. Any advice appreciated.
