ENGINE OIL
Ryan Rognstad
If you had to choose, which engine oil would you prefer, which do you have good experiences with? for example Castrol or Pennzoil. Also whats the farthest you have gone before changing your oil.?
chemingthroughtheleather
I'm just getting ready for my first oil change,I have decided to go with castrol sae30...at the end of this mowing season I'll probably go with mobil one synthetic.
Nwatson99
Castrol 10w-30 change my oil and filter every 50 hours.
Several folks have said it is good to do it that way, but they also said might be too excessive and if I want to do the service early I should at least run the mower for 75 hrs since the manual states 100 hrs.
Bison
About 10 years on a cast iron kohler,.. till the rod came trough the block...I just kept topping of the level.
PS: a rod bolt came loose,..had nothing to do with the oil ;)
I use W30 in all my little gas engines and 15W40 in my diesels.
Synthetic is over rated and to expensive anyway but it helps with easier cold stars in the winter.
X-man
I use Mobil 1 10W-30 with a Purolator oil filter, changed about every 50 hours.
Which equates to once a month.
X-man
I'm not a big fan of Pennzoil. Heard both good and bad things (more bad than anything) about it.
Fram... I hate Fram with a passion.
All you have to do is take a Fram oil filter apart and see how poorly built it is.
Ric
Here we go again
Oh but it's so much fun :laughing:
I change the oil filter every 50 hrs and use Mobil Super 5000 10w30 from Wally World cost me 12.97 for five qts
Av8r
Mobile 1 10w-30, kawasaki filter, every 50 or so hours...overkill, but I like a clean engine :laughing:
