Mad Mackie
- Jul 11, 2011
- 1,851
Hi Troops,
Over that last few weeks my Scag Tiger Cub has developed an engine oil leak. Today I removed the engine and checked where the oil is leaking from.
In the pic with the blow gun tip is pointed, the engine base gasket is where the leak is located. It is a metal gasket and when I blow air in this area, the crankcase vent valve whistles. I won't be able to get into the engine today, but for sure I need to clean it up before I do!
I was looking at the parts manual for the engine that has replaced this engine and I see where there has been a change done to both the crankcase and the oil base. When I get into this engine I will call Briggs to see what they recommend. This was a new repower engine in March of 2013 #49M977-1036 and has only 450 hours on it. Replacement engine is #49T877-0004-G5
As you can see in the pics, the clutch is wet with oil!!!
Fortunately I have a backup tractor:tractor: with a 48" deck and collection system to do my lawns while my Scag is in dispose!!!!
About a year ago I gave away my parts cleaning machine figuring that I would not need it anymore!!! Oh well!!!
The plywood that you see in the pics is the covers for the pit in my garage, nice to have it!
