magnum308
- Jan 22, 2017
- 11
- 30
Just wondering if anyone can advise me about this.
I have just done a service on my GT3200 with Kohler Command 25 engine. Cub manual says sump capacity is 64 Oz (equivalent to 1.89 ltrs) another source I found online says 1.9 quarts (equivalent to around 1.8 Ltrs). I have just filled the engine with new oil and it took 1.55 ltrs and says it's about up to the full mark on the dipstick. This is after running it for a bit to fill the new oil filter and adding some oil after that. The mower has seen some work with the previous owner and has down around 715 hours (on the dash meter).
Any thoughts would be appreciated. Thanks in advance..
