engine loses power when...
nybuckboy
I have 2012 Ferris Pro Cut 3 wheeler with Kawasaki engine with about 400 hours. Used it for several hrs yesterday and it was fine. Went to start today and it was dead. Jump started with truck and took right off. When I engage either the lift or mower deck it loses power and dies. The 4 fuses under the steering bars and all good. Thoughts??
You possibly have a bad battery.
Get it load tested...if good...charge it to full strength
If bad..get a new battery and see if your problems are fixed.
Lift and mower deck take a lot of power...
