Georgia Boy
- Jun 18, 2012
- 1
- 7
I have an unusual problem. Occasionally, the engine on my mower locks up and the starter is not able to crank it. I have to rotate the flywheel back and forth to free it up at which point the starter will engage and start the engine. It doesn't happen often but when it does, the starter won't budge the engine.
The engine is an 18 HP Briggs Vanguard. It has a new battery and solenoid but the starter is original. Any suggestions would be appreciated.
