engine is hard to turn over
lray
the engine on my ridining mower is hard to turn over. tried a good battery and changed starter. it didn't make a difference.
Post your engine numbers, my ESP is fuzzy and the government spy satellite is down true to sequester. If it is an OHV engine , I suspect you will have the adjusted the valve clearance.
Ifixdit
Pull your oil dipstick and check the oil level. If it's unusually high, you may have debris in the carb and the needle might not be seating properly and filling the crankcase with fuel. That would definitely make it hard to start. Good luck and keep us posted.
