Mr. Mower
Doubt it's the starter on mine as it will crank and crank. Sounds like fuel delivery issue.
On the solenoid, are you referring to the fuel cut off solenoid in the carb?
Could it be a fuel pump issue? Are those fuel pumps driven off of engine vacuum?
As previously mentioned, those technical problems that I listed are from researching "starting issues" for the Hustler mower (from various other post, forums, youtube, calling Hustler Corp. and speaking with engineers, etc.) and are just your average starting issues that one may encounter (especially if the unit is still under warranty, keep in mind).
Yes there could be various other known problems (depending on how old and model your Hustler mower is?) and your issue could very well be fuel involved as you stated.
Like everything else it appears as though you will have to trouble-shoot and diagnose and research your problem for your specific Hustler mower model.
