engine baffle?
RPM1970
I have a Tecumseh engine 13.5 h.p. OV358EA, engine. I need to know the size of the bolts that connect to the dip stick 1?. 2 one is at the back where the spark plug is at? and the 3 one is on the other side from the dip stick? when the shroud is all connected to the baffle I believe it should be tight. its loose and I am afraid that the baffle will hit the electric starter if any one can show me the right Diagram for this engine it would be of great help. if you need pictures, I think I can take some, let me know what info you will need. Ron here
Do you have the spec number? is this the spec number742-06-10A
I will check it tomorrow on the engine look for the plate with the date of the engine.I am always willing to learn. I do home remodeling for my self .if you try hard enough it will come out great
These are the screws numbers161- 252 there should be another one near the spark plug? plus what hold the baffle number 25 down? i see screw number 26 I don't see where that hold down the baffle the only one is number 252 that hold down the dipstick and to the baffle .But the baffle seems to move to the electric starter. not sure when I will return I have test to be done
252 |650976 |Screw, 1/4-20 x 19/32" shouldered.
161 |30063|Screw, T-30 Hex Washer Hd Sems, 1/4-20x1/2
Screw item 26
26 |650561|Screw, 1/4-20 x 19/32" serrated flange.
Item is held down by two of the 650561 in the indicated locations.
Star tech that baffle plate isn't like the one I have. When I put the shroud over the plate to tighten it down. it has the 2 outer bolts but it moves a little bit. but there are none on the bottom of the plate. to hold it in place. model OV358EA.Would the shroud and the baffle interlock with each other to make it tight I am worried it will go into the electric starter?
