Fish
- Aug 2, 2013
- 11
- 5,145
Looking at the top of the flywheel, it is evident that the fanwheel is held on by the two bolts. The service tech telling you that your installing/removing the flywheel would not affect the warranty is "bogus", you need to step up and "prove" that one.......
As far as you having a good running engine that all of the sudden had totally "reversed" timing marks, that is impossible to believe as well....
For us to consider this thread any farther, you might need to tell the "whole" story, if any of this tale has any credence........
Otherwise, we have better things to do.
If you fess up and are talking about an engine that you bought from someone else, and the info you provided is secondhand, well.......
