- Sep 7, 2024
- 3,515
Seeing how the problem seems to come and go, remove the top engine cover and inspect the starter closely for a worn Bendix helix on the shaft and the gear teeth that contact the flywheel. Watch the starter gear motion when you try to crank the engine couple of times. The starter Bendix gear should make consistent mesh contact with the flywheel gear.
A starter this age may also have badly worn internal shaft bushings, and the starter needs to be replaced.
