tjdunlap
- Jun 20, 2021
- 6
Mower hunts & surges while idle as well as while mowing. I've replaced the following with genuine B&S parts (where appropriate):
My next step is to remove the head cylinder (and replace the head cylinder gasket #692249) to clean carbon deposits with a stiff wire brush. If that doesn't work, my next adventure would have me examine the values and valve springs.
What else should I be looking at? What am I missing?
- new spark plug
- fresh gas & oil
- base primer #496116
- filter pre-cleaner #493537S
- filter #491588S
- replaced carb #790845 (cleaned old carb first even used carb bushes; no change)
- manifold intake #497465 (wasn't cracked, but figured a new one couldn't hurt)
