and probably due for valve adjustments..
If it isn't broke leave it alone.
That's kinda what im thinking. Lol. Think I may take carb off and clean and rebuild. Running a little rough due to varnish on needle valve I believe.
If you haven't all ready done so maybe try all new filters and a spark plug first. Just when is it running rough? More then varnish on the needle valve I would think, it would be partial plugged high speed jet inside the carburetor for rough running.
How hard is to change high speed jet? Has new filters and plugs. Can I dip carb in gallon of Berryman cleaner for an hour?
Thanks
All the high speed jet would need is a cleaning. If you were to go that far invest in a rebuild kit which includes all new gaskets and a new needle valve. I don't know what Berryman cleaner is but it sure sound good to me. After the dipping blow out everything with a aerosol can of carburetor cleaner and compressed air. You should be good to go. If the carburetor is really dirty inside dip it overnight instead of only one hour.
