Elh 775 Kohler EFI water pump problem
Jhead2
Was replacing the water pump which is located behind the flywheel. While removing the transfer tube on the water pump going to casing on the motor the 90 degree fitting came out of the casing.It is not a threaded end and looks like it may have been pressed in.Has anyone had this happen to them and if so what did they do.thanks for any help.
