- Dec 7, 2022
- 2,236
Engine: Kohler Command Ch740
Issue: Engine will not start unless jumper wire is hooked to ignition switch on solenoid pole and touched to trigger pole on solenoid. I have three different zero turns that I have experienced this on. Two have Kohler Command engines and one has Vanguard 61E877.
What I have done: Temporarily bypassed, swapped out, and tested the relays, safety switches, ignition switches, and fuses. Cleaned all electrical connections. Did visual inspection of wiring. Tested with multimeter. Checked battery by load testing and checked and confirmed good grounds.
This is driving me crazy. Can someone please help?
Thanks
Thanks
