Paul Caruthers
- Apr 2, 2016
- 1
- 4
Hello all, just joined your forum, Hope someone can help me out. I recently bought a nice Sears Craftsman Rider Mower, 18 hp Kohler Magnum, I believe it is about 10 yrs. old? low hours really clean and untampered with.Using the owners manual as a guide, I began going thru it to make sure everything is as it should be. But....coming from the backside of the ignition (key) switch, terminal G is a single black wire that goes to a spade connector (not plugged in) and nowhere obvious to plug it in. Also, at the spade connector another black wire feeds in, but this was cut off from itself- the apparent source being the A terminal of the pto switch. I am confused because this differs from the schematic in the owners manual. If someone with the same or similar mower can look at my pictures and compare to their own ? and provide me with the right answer? It would seem they are all grounds, but that spade connector should plug in somewhere, and it only goes 12 inches from the ignition switch max. Thank you for any help, Paul Caruthers
