rancher_mac
- May 10, 2023
- 34
I have a Briggs opposed twin 17hp and I’m looking to potentially swap to electric fuel pump. Main reason being I hate the design of the pulse tube going to the crank case (potentially thinning oil with leak). I use high grade ethanol free gas and baby my carbs, but these carbs seem to give me trouble with their pumps…maybe I’m just unlucky. I had a couple questions regarding the pump input if I converted. Would I be able to plug the pulse feed and just put the inlet into the existing inlet on the carb? Or would I need to drill out and tap in the hole I circled in green? I’m looking to use this specific pump which is 1-2psi.
