Electric cut height system HELP NEEDED
Redlawnlizardlady
need help. The electric cut height adjusment system on my Snapper 285Z 27hp is not working. Adjusment button makes the usual humming sound when pressed and we can see the bolt turning in either direction, but the deck does not move. Owners Maunuel does not have any information or diagrams of how hookup should be. Is there any kind of diagram out in this forum. Does anyone know if there is any kind of saftety lock that might be engaged, where it might be and how to reset it.
Thank you
Redlawnlizardlady
MParr
Look on both ends where the actuator mounts. If the screw is rotating, that means the motor is working. It could be broken where it mounts on either end or the female threads can be stripped.
The part will cost around $175.
You will need your model number and serial number. Enter them into the link below.
