Electric clutch needed
Need some help locating an electric clutch. It is for a Jacobson Chief 1200. The engine in this unit is a Kohler 341 and the clutch is mounted vertical on the side. If my search so far is correct it is a Warner clutch #5208-32 or 5208-29, but the clutch has no numbers. I have not been able to find a parts breakdown to get a part number, which has made a difficult find.
Carscw
Does it look like this one?
Ford 120 k301
Just found a manual and the parts number is 500577.
EngineMan
Looking at other web site they say that the parts for the clutch are hard to find, but the old wheel horse and ford 110 have the same set up, maybe worth you looking into it, if you have not already done so...!
Have seen that the Ford and Jake should be the same. I'm now trying to figure out the differences between the Warner 5208-29 and 5208-32. The back side of the clutch is threaded on to the crankshaft, no keyway. Forgot to look if it is laft or right handed. Customer wants it repaired, but at what cost?
