Echo SRM-265T will start and run okay, not really have power, and then when you floor it, it sputters and actually backfires and pops. I bought a new carb for it thinking that it was just another EPA carb problem, but it didn't improve the situation at all. I pulled the exhaust and checked the rings to see if they had possible stuck, and letting by gases, but they seemed fine, I suppose I could check compression, but it starts so well I just don't know, any suggestions?
