Echo SRM-265 problems
Who Dat Tigers
I have an Echo srm 265 and it will not kick into that higher gear so I can use it, any help?
KennyV
Is that not a straight shaft trimmer...?
I was not aware that it had a transmission of any kind, other than the fixed angle drive at the head... :smile:KennyV
Who Dat Tigers
I am not to mechanically inclined, but what I am trying to say is that the engine does not get to its fullest so the weedeeater is not able to cut.
KennyV
Likely carb cleaning OR rebuild will get it going...
Here is a video of a cleaning of an echo (Not your exact model) BUT very similar carbs
YouTube - ‪Carburetor Rebuild on ECHO Grass Trimmer Part 1/2‬‏
and a reassemble (similar carb) yours has a purge, primer bulb...
YouTube - ‪Carburetor Rebuild on ECHO Grass Trimmer Part 2/2‬‏
Take your time be patient and you can do this... 2cycle carbs seem to be very fuel quality sensitive and thus need a bit of fiddling...
A change in type or mix ratio of oil will also make a difference and can require a bit more fiddling because if you mix More oil you are effectively leaning the fuel air mixture... once you get it right and you stick to a particular fuel oil mixture, It should remain pretty good until the gasoline quality changes a little ... then a bit more tweaking at the caarb will get you good again... This looks and sounds a lot more difficult than it actually is...:smile:KennyV
Jetblast
I have one and it's unforgiving of any fuel/oil mixture differing from 50:1. Too much oil and it acts like it has the choke on and won't rev.
Briana
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
bladeruner
i have run into the same issue. mine was the blade adapter at the angle head was broken. and creating friction enough to keep it from spinning up to full speed. so when it was installed it rubbed the other parts. once it was replaced it was cured. i hope this is your fix. and i have helped in someway.:laughing:
sawman024
Hello,alot of times the muffler spark arrestor screen gets clogged solid with carbon and the exhaust can't escape properly
Edwards saw service
A lot of time the high speed adjustment needle screw needs to be turned out a bit to richen the gas mixture for the carb. To do this start the trimmer and let it warm up. The take a tiny flathead screwdriver and turn the mixture screw out while giving it a little throttle to see if the engine is getting full throttle rpms. the adjustment screw is located on the side of the carb towards the bottom near the recoil starter assembly.
Edwards Saw Service in Glen Mills PA
Mowers007
Mowers007
G'day mate. I think you are mixing to much oil in your fuel if this happens regularly or you may be using a poor quality oil. Try using a good quality oil and mix it at 50:1 ratio and see how you go. Cheers
