natenkiki2004
- Apr 22, 2011
- 13
- 177
I picked up this trimmer locally for $10. It looks like it was beat up pretty good, perhaps dropped. In dropping, the plastic shroud has a crack and one of the exhaust bolts sheared so the muffler was used loose. I think the exhaust got where it shouldn't be and stressed the ignition coil. The coil has a bunch of cracks in it. I heard of baking coils so I did that and some oil came out and it worked, briefly. I baked it again and it seemed to work just fine. I sealed the cracks with Permatex Black and got it back to the barn and installed it, no spark now. I think the coil just needs replacing. I've found some for $50-$60. Is it worth it? I might need a gasket kit for about $20. I can fix the exhaust bolt easily, I've done it before. Should I invest in this trimmer or just scrap it for parts on eBay?
