Echo SRM 230 Questions
tank1949
I lost compression on my 230. I pulled cylinder apart and noticed two rings on the piston. I also found a video tutorial on a SRM 225 (not 230) that shows ONE ring. Mine has two! Two vendor online parts stores only list one ring part number. Yet, their schematic shows two rings. Does my SRM 230 require 2 rings of the same part number? Or, are they unique? I am used to rebuilding four cycle motors that have specific and unique rings on each piston. Also, does the cylinder wall require honing before reassembling?????
Don't really need honing as these are plated and honing wear away the plating.
Second need the unit serial number for parts look up but all the SRM-230 IPLs on Echo site does have two rings. It appears all serial breaks uses the same 2 ea A101000000 rings.
tank1949
Ser is 06041195-thx!!!!!
