Hi.
model = SRM-225
SN = S039126662268
From the parts diagram (attached image), the choke lever (which is an integral part of #6 "Case Assy, Air Filter") gets stuck on #5 ("Plate, Prevent"), whenever I tighten the two torx bolts. This getting stuck issue happened spontaneously, as far as I can tell. I never opened/cleaned this before. That said, I certainly opened now and there was nothing out of place. It was all very clean. Nothing broken or deteriorated.
Any advice is greatly appreciated.
model = SRM-225
SN = S039126662268
