scotttaylor
- Apr 30, 2011
- 1
- 1
I have an Echo SRM-210 S/n in the mid 800000 that is having problems. It would only crank and run in full choke and would die if given any gas at all. also it would die if you moved the choke. I have rebuilt the carb and replaed all gaskets, hoses,filters and primer. I have taken it all apart, carb cleaned it and still nothing, maybe even worse than before. The only thing I can possibly think could still be wrong is the high speed jet. Can anyone tell me how to remove the plug that keeps this jet in place? I have seen that both Items (plug and jet) are available in replacement parts. I have tried everything I can think of, so any help would be greatly appreciated.
