NowThatsDamp
As title reads. I was using it, it was running great, shut it off and set it down. Picked it back up 10 minuites later... No spark.
- No spark with new or confirmed working spark plug.
- Ignition coil resistance is within spec
- Ignition coil gap is good
- Confirmed continuity between plug and ignition coil, at resistance spec
- Switch wiring inspection passed
- Switch inspection passed
- Tested it while bypassing the switch anyway, nothing
- Magnets feel strong, but I don't know how to properly test them
- I've also been shocked a few times while pulling the chord, whatever that means
The coil has a small bit of rust on the top, and the magnets are ever so slightly browned. Maybe 2% brown colored.
I'm at my wits end. Please help.
