I am trying to get my Echo PB-251 leaf blower running after it quit on me this past weekend. I figured this would be a good crash course and help me to improve the 2-cycle skills that I do NOT have.
Air, spark, fuel - that simple, right? Not for me. I have done the following:
1) confirmed that I have a blue spark on the plug. Even though that checked out, I installed a new plug.
2) checked the air filter. I replaced it last year as part of a tune up kit. Looks good and I tried to starting it with this removed. No luck.
3) spark arrestor - I hear these can get clogged and cause symptoms so I removed this to clean it but it was already clean from the last time that I did this.
4) fuel? Not sure so I removed the fuel filter which was also replaced last year. I do get gas into the primer bulb so I don't think there is a problem with the fuel line. I also tried to eliminate fuel as the issue by putting some directly in the cylinder and trying to start it. No luck.
5) I replaced the carburetor just in case it is the fuel and because the tech at the local mower repair store said that this must be the problem due to my summary above. No change after installing a brand new carb.
5) compression - I used my harbor freight gauge and it showed 70 PSI. I know this sounds low and my gauge might also be suspect. I also looked at the piston and ring through the muffler/exhaust and iI do not see any evidence of scoring or damage. This is limited as far as what I can see. I did add some 2 stroke oil directly into the cylinder since I heard this can help if the compression is too low and sure it enough, it tried to start and created smoke and a small firing bang.
This is not about the money but about understanding this 2 cycle and making it run.
Can you help with some next steps and recommendations on what to check?
