Echo Blower PB200
rabbit
Echo Blower
PB 200
It is possible the blower got submerged during a storm
It ran great before.
Now it wont take the gas and run above idle.
I have changed the gas, rebuilt the carburetor {soaked and installed new kit}.
Cleaned the flywheel, just incase there was something affecting the pickup.
Changed the spark plug.
New bubble pump.
Cleaned fuel filter.
Still will not run above an idle.
what am i missing here?
thanks in advance, randy
Ric
Have you cleaned the Spark Arrestor?
rabbit
no I havent. I am going to take a guess here and hope that you mean the muffler?
Thanks for the suggestion and will get back to you.
randy
Ric
randy
It's a screen mounted on the side of the muffler. Clean it with a wire brush.
rabbit
Ric, thanks so much for your advice.
I clean the spark arrester. It was very clogged.
The blower runs like brand new!
Never had to do this before but I may check my other two strokes just in case.
It certainly cant hurt!
Wish i could buy you lunch sometime.
I learned something new.
Thanks again, Randy
exotion
You can also remove it. If you do please don't lay it down on anything dry and flamable
Ric
Thanks again, Randy
No problem Randy. The spark arrestor is one of those things that always gets over looked for some reason. I always check for the simply fixes first. I clean mine a couple of times a year.
Yes you can remove it but it's not advisable. A spark arrestor prevents the emission of flammable debris from your mowers engine and shouldn't be removed and in a lot of places their use is required by law.
