Hello Everybody. I have a new Bad Boy ZT Elite w/ 20 hrs. on it. Mowed 3 acres for the last time this season on Sunday. Washed the machine then moved it closer to the garage door so my air hose would reach. I blew the machine dry. Ate dinner, went outside to move the machine inside the garage and it wouldn't start. I new the machine had power cause the hr. meter was working. Battery was fully charged. Upon further inspection, I noticed the brake when pulled back wasn't making contact w/ the shut off mechanism-it didn't depress. The brake handle was a little loose. I removed 2 upper bolts holding the gas tank which allowed me to tighten the brake handle. Now everything lines up and the machine started.
