eager 1 problem - prime push bulb 20 times - runs for maybe 10 seconds - stalls. think i have a fuel supply issue, have cleaned carb, replaced the needle and seat because originally gas was leaking from the air filter - reassembled no fuel leaking but will not run. i'm wondering if a fuel filter could be causing this. cannot find the fuel filter!!! this is a eager 1 917 383270
